aizan
haven't taken any photos, but i've got a nikon f w/eyelevel prism, canon new f-1 w/ae prism, and a pentax spotmatic. one of these days, i'll get a ff dslr.
			cmogi10 said:I'm impressed by the lack of DSLR pics...(and I know there are a couple, just not a lot)
	I don't get vignetting. I bought the hood separately; as far as I know it's the one for the 50/f4 Flektogon, and it's identical to the one or two other Flektogon hoods I've seen. If it is the model for the old 65/f2.8 Flektogon, then it doesn't vignette anyway.JasonC said:Are you using the 65mm square hood on your 50mm/f4 Flektogon? Do you get vignetting?
	rxmd said:Hi Jason,
The hoods can be difficult to find. The lens has a 86mm filter thread, the hood has a 95mm thread, and you need an M86/95 step-up ring to use the hood. Then again, the Flektogon does profit quite a bit from the hood, and with the square format on a 50mm lens it is easy to get bright light sources where they shouldn't be, so the hood is definitely a good idea.
Philipp
nikola said:Pete I just bought X-300/370 Seagull clone, DF-300, for 40$ in great condition... as new... I would even dare to say new!
A little more than 16 cm.JasonC said:Could you measure the inside diameter, corner to corner, of you hood?
Sonnar2 said:It's amazing how many of them still work after 35 years. Compare it with Canon EF, Pentax ES, Rolleiflex SL35ME - all these first gen. AE-SLRs were heavy and big as brickstones. The computerized FE, AE-1 and ME stuff need 5 more years to come
