mh2000
and a "color" scan "converted" to b&w is an average of 3 "positive scans off a b&w negative," conceptually it is the same, only you are approximating a multipass b&w scan instead of just a single pass b&w scan. For digital sampling, a multipass scan generally reduces scanner noise without altering your image at all. I don't get fancy during conversion, just Convert to Grayscale in PS or Save as Grayscale in Vuescan... both bias the average toward the Green channel. Through a fair amount of testing, this yeilds much less noise/grain aliasing than a straight "b&w scan" with my scanners (especially when scanning C41 b&w and using DigitalICE).
Another vote for scanning in 16 bit gray scale.
Output is positive scan of b&w negative.
Vuescan/Minolta Elite 5400
