Michael Tyler
I've been shooting a 40mm on my M2, and today picked up an M7 as well. Does anyone know if the M7 35mm framelines work well enough for a 40mm? The M2's framelines are pretty great for it.
If you purchased a "normal" stock M7, then it has a VF magnification of 0.72x which is the same as the M2. Therefore framing a 40mm should be no different
Nope. Until the M4-P (brass-top) all 0.72s VF had identical frame-line size, starting with the late M4-P Leica changed the size of the frame-lines (to adapt frame line coverage to a different focus distance).
Interesting. Are you talking about the actual frames themselves or the relative spacing of the frames within the VF?
35mm on 0.72 VF is about showing 38mm actually.
The 35mm framelines on the M7 (and M6 and newer cameras) are closer to the fov of a 40 than a 35. Cameras from the M6 onward have a frameline mask that shows what will end up on the negative at 70 cm. The older cameras show 1 meter. So the area indicated by the framelines in the newer cameras is a little tighter.
As an example the 50mm markings in pre-M6 camera are a good match for that focal length at most distances. In camera from the M6 forward the 50mm markings are closer to a 60mm at anything but the closest focusing distance (70cm).
I've been told that 40mm works best on an M3 using the whole viewfinder, but I still haven't tried it.
