50mm Summicron v3
Forgot to add: I scanned/digitized these negs no differently than I do with convential bw film and developers. I used an Epson V600, using the Epson software to adjust the histogram to get the broadest range of tones I can out of the negative. I then make minor, further adjustments and clean up in LR.
I like the pictures too; Steve, I've never heard from this film and this developer. Great sharpness and tonality.
Erik.
Thanks, Erik. I became aware of this developer about a year ago, and my sense is that it’s pretty new (I’m sure I’ll be corrected if it’s been out for awhile). The chemistry eliminates the need for fixing as a separate step in the development process. You develop for a period of time depending on whether the developer is fresh or has been reused, at prescribed temps that are a little warmer than 20C, and then rinse/wash when the development time is up. I was skeptical at first about eliminating the use of a fixer as a separate step, but the results look pretty good to my eyes. D96 Monobath won’t replace Perceptol, HC 110, or Diafine (the other developers I regularly use), but it’s a nice alternative and appears to have been designed with Double X in mind…
Steve, I just shot my first roll of Double X and am also about to venture from my usual Rodinal to HC-110. Have you tried using that one with Double X, and if you'd be willing to share dilution and times, I'm all ears 🙂
David
David
I have not yet used HC 110 (or LegacyPro 110) with Double X. Some of my early photos with Double X were developed in Diafine, but mostly I’ve used D96 Monobath. There seems to be a sweet spot with D96 Monobath at around 7:30 mins. at 22C, using Double X, where you get nice tones and grain. The photos below are some recent examples… not taken with a Summicron v. III, so we’re venturing beyond the theme of the thread, but since you and a number of others have expressed interest…
Nikon F2, Voigtlander Ultron 40mm f2.0 SLIIs, Cinestill Double X, D96 Monobath, 7:30 mins. @ 22C:
At Yosemite Falls by Steve Macfarlane, on Flickr
Cascade by Steve Macfarlane, on Flickr
Yosemite Creek by Steve Macfarlane, on Flickr
The tonality you are getting is fabulous! Particularly for me in those first three w Nikon F2 and Ultron (not that it's the camera or lens 🙂 Thank you for sharing. I will start with HC 110 because I have it here and go from there 🙂
David
David
DwF, I shot through a bulk roll of Eastman Double-X a few years ago and developed most of it with LegacyPro L110. No on-topic photos to share with the 50mm Summicron v3, but for developing dilutions and times at 68 degrees F, I settled on 1:31 for 5.5 minutes for ISO 200 and 1:31 for 6 minutes for E.I. 400. YMMV in your own workflow, but hope that helps with some ballpark starting points. I have an album of sample images with Eastman Double-X on my Flickr with notes on my dilutions/times.
Thank you for that! 🙂
