Equation for Tempering a 1:4 developer mix
JSturr
9:10 PM
For some this ratio/equation may be a no brainer... but to come up with it I had to dig deep with some mental gymnastics.
Tempering a 1:1 D-76 mix is really a no brainer ratio. ((x temperature) + (resting developer temperature mix))) / 2 = 68
Basically you averaging everything out to get to 68 degrees.
But -- I've switched from a 1:1 D-76 to a 1:4 Ilford Ilfotec DD-X.
So -- I looked at the bottle -- looked at my graduated cylinders -- then looked at the bottle again - and when --uuhh.....
This is what I came up with --
I keep all of my chemicals at a resting indoor temperature - and that varies and is never a perfect
68 degrees.
I know I need a 1:4 mix -- 1 part developer and 4 parts water. This whole mixture equals 5 parts.
These 5 parts need to have a a final temp of 68 degrees === 5(68)
Here's the ratio/equation
4(x water out of the tap to temper) + 1(resting developer temperature) = 5(68)
so -- for instance -- let's say my resting developer is 72 degrees and I want a 68 degree 5 part mix.
4(x) + 1(72) = 5(68) x = my needed water out of the tap to temper the 72 degree developer
4x = 5(68) - 72
4x = 340 - 72
4x = 268
x = 268/4
x = 67
So -- 4 parts of tap water needs to be 67 degrees when mixed with the 72 degree Developer to = 68 degree mix.
