spystyle
I have a bunch of circular filters, mostly 52mm
I'd like to store them in a way that is easy to identify and access them.
I was thinking of making some kind of case out of wood. Or maybe using a CD-book.
If I had a sheet of 1/4" plastic I bet I could cut that material with a jigsaw and fit something inside a suitcase that holds filters in a nice way. But I don't where to buy sheets of plastic...
How do you guys store your filters?
Thanks,
Craig
Thanks,
Craig
ray*j*gun
There are commercial pouches that have clear pockets...I label them with a Sharpie.........also If they are the same size I will make a stack VERY loosely then put the stack into a clear plastic sandwich bag. I have so many filters that I need to use both methods. B&H has the pouches as do other vendors.
Jan Van Laethem
Nikkor. What else?
To save space, stack them together as suggested and use some metal stack caps like these for extra protection.
http://cgi.ebay.com/52mm-FILTER-STA...emQQptZLH_DefaultDomain_0?hash=item335580ed9a
These caps are very cheap, give adequate protection and double up as a lens cap should you loose one on an assignment.
Roger Hicks
Stacked, with end caps or with a cheap-n-nasty second-hand filter on either end, preferably with an X marked on it to remind you.
spystyle
Thanks for chiming in, I have seen the sandwich bag style storage. What I'm interested in is probably more like a suit case with levels... I guess I'll have to make it myself unless I see something similar.
Thanks also for chiming in
What really interests me is a method of storage that makes them ultra-accessible, well stacked, and sensibly protected.
Maybe I'll invent something
spystyle
Thought provoking ...
Do you guys have any pics of your setups ?
Gumby
Filter wallet. Several. (snip)
Ditto. Seprate wallet for different size filters. When the number of filters exceed the capacity of the wallet, I organize into different wallets according to type of filter: e.g., B&W and CC filters in one; star and soft-focus in another.
ron1945
filter box?
filter box?
i use an old plastic floppy disc case,very good if you can source one and they have flick partitions keep your eye open in thrift shops
filter box?
