IDCOO variations?
shawn
9:59 AM
I have an early version of the IDCOO (front flap is sew on the bottom) and wanted to know if there were other versions where the front cover lens depth is deeper?
I'm trying to see if there is a version that will fit a M3 with the Voigtlander 50mm 1.5 Nokton with a filter and lens cap. With both the cover can't close due to interference. With either filter or a lens cap on it will close but bulges out a little. The goggled version would probably fix the interference but I think the depth would still be an issue.
Understand arguments against the never ready case, but wanted to try this for a bit as a minimal carry. If this was a later version with the stud on the back I'd change that out for a snap to make it removable. Only looking for versions with strap lugs on the case.
Thanks!
Shawn
Just an update on this.. the IDYOO case (with a rivet to hold the cover on) will fit with the Voigtlander 50 1.5 Nokton with a filter and lens cap on but the lens needs to be at infinity and it does bulge slightly. With just a filter or lens cap it fits easily.
Shawn
