xasthur
Hello everyone!
So I finally got my dream camera the M2 but per my luck with things it's got problems which I was not aware of.
Please note that I bought this camera with mindset of it was working perfectly because the owner said it was CLA'd 3 months prior.
The main maybe issue/question is I have a after market adapter that I'm using for it with my 35mm 3.5 Elmar LTM lens. Reason is I got it for free so why not give it a go. The weird thing seems to be when I focus the lens to about 1,75 meters the rangefinder doesn't seem to focus any closer. It's like a dead zone with anything under 1,75 meters. Is this normal? with the LTM lens? Could it be the adapter? Below I have a picture of the adapter. I have pictures of the adapter below.
Also, a bigger problem appears when I use a shutter speed above 1/125 of a second. Basically what happens on the shutter speeds is what I believe is "capping" when I release the shutter there's no exposure through the curtains and I end up with black images which leaves me to believe the curtains aren't adjusted correctly and the timing is off. Does that make sense to anyone? Also note that all the slower speeds are perfectly fine.
With that being said I do have the proper tools to take the bottom plate off and to make curtain adjustments if anyone has advice or have done this themselves. I'm fairly confident in my fixing abilities as I've been buying broken cameras and fixing them for over a year now.
Thanks!
https://i.imgur.com/uktFqq8.jpg
https://i.imgur.com/YlfKKvO.jpg
https://i.imgur.com/7wSmT8D.jpg
https://imgur.com/pdZJyL5
https://imgur.com/XgGEhWP
https://imgur.com/41llHlU
https://imgur.com/WU78npW
https://imgur.com/AuH4tYt
Thanks!
