Pieter12
I want to use a 28mm on my M5. Does the entire viewfinder frame (beyond the 35mm guides) give an adequate approximation of a 28mm lens angle of view?
Short answer (though less informative than Cal’s): yes.
I framed this to include the banner as well as the man setting up his tent and the overall context—a homeless camp near an interstate viaduct. M5, CV 28/1.9.
Thanks, Daniel. It’s from a 2011-2013 period where I was documenting Occupy and a related homeless-centric movement, SLEEPS (Safe Legally Entitled Emergency Places to Sleep), in Eugene, Oregon.
This camp was across the boulevard from the local Ninth District Federal Court. I was there when it was shut down and the activists moved elsewhere. Now there are a couple of city-sanctioned/activist-run sanctuaries.
Back to topic: M5 VF margins approximate 28, but with my Hexar RF I can frame 21mm without resorting to the OVF.
P,
28mm on a M depends...
I wear glasses and though my M6 has 28mm frames I have to scan with my eye when composing carefully.
I imagine if I did not wear glasses that the 28mm frames otherwise would be fine.
Same issue here. I also wear glasses and the frame lines on my M6 are pretty much unusable. I have however recently bought a voigtlander 28mm external finder, to use with my M2 and found that I can actually see the frame lines on it with my glasses on, so I use it with my M6 as well.
