Using an SB 15 with a Nikon D40?
Spider67
5:52 AM
I already read that it can be done, but how?
When I put the flash on the camera (which is on "P") it works but the camera still takes a speed as if no flash is attached.
I am very thankful for pointers how to make that combination work.
Best regards
Des
The SB-15 is not compatible in P mode. Set to M and use it in manual settings..
I'd play with some different combos. Camera in M mode at f/4 or 5.6 and shutter speeds around 1/60-125. Flash in A mode and try either A1 or A2. I have the flash and use it on my GF1 as a bounce flash. Settings: ISO400, 1/60, f/4 and flash on A2. This works well as a bounced flash off my ceiling and lights up the front room pretty good.
