jamriman
Anyone bought this lens? It looks sweet. Thanks
boilerdoc2 said:Anyone able to get around this issue with Zeiss lenses?
Steve
New flange - coded, the M8 is convinced the Biogon 21 is an Elmarit 21 asph. Works like a dream.boilerdoc2 said:I would, except how would you code it? the 21 would have some real cyan shift if used with an IR filter. Hand coding with a sharpie is a hit or miss affair. More miss than hit for me. Anyone able to get around this issue with Zeiss lenses?
Steve
Tom A said:I just recieved my 21f4.5 Biogon. Stuck it on a M2 (because that was the one that had film in it!) and will proced to shoot with it for the next couple of days and let you know what it is like. I have the old 21/4.5 in Contax mount so it will be interesting to see how they perform side by side.
The hood is the same as for the 21/2,8 ZM so it will block the finder in the R4M a bit, but I suspect that there is another hood for it. The 25 mm ZM hood works too, though I dont know if it will vignet (yet).
I am "unthawing" some rolls of Fuji ACROS for "testing" this lens against the old Biogon and the 21f4 VC and assorted 21/2,8' as well as the 21/3.4 Super Angulon.
They have promised nice sunny weather for the next little while, so this will give me an excuse to wander about with various lenses.
It is slightly bigger than the 21/4VC in M-mount, but smaller than the 21/2.8 (same diameter of the barrell but considerably shorter).
sepiareverb said:As am I Tom. Any chance of hacking this like you did the Super Angulon?
Tom A said:...Ah. the hacking of the 21/3,4!...It kind of worked, but the R4M is a better solution!
