Ruben
I'll locate you a circuit diagram for the Kievs exposure meter - next.
The potentiometer is the brown circular thing underneath the circular exposure calculator.
If you still had both your Kiev cells the first step would be to compare them by selecting volts and seeing if both cells gave the same voltage when exposed to the same light. If one gave no volts you would need to store it for later experiments. If the cell in the camera was similar in voltage to a new cell it would not be worth while replacing it. (note in situ there are two resistors across the photo cell, the potentiometer and a fixed resistor, hence the need for the circuit diagram.)
The next step would be to see if the both ends of the pot (potentiometer) were connected (a hair line crack in the substrate would spoil our fun).
I dont recall doing more then checking mine in situ with a multimeter, and resetting the galvometer needle suspension, (the bearings the needle rotates on).
The adjusting screw just moves the paper scale cardboard, so that the meters rest position is the black dot (I think).
First what seems to be wrong with each of you Kievs to hand apart from the one with a cracked potentiometer substrate? Fixing the easy one first will be the easiest...
Noel
I just had one of the meters fail so I understand your problems.l
