waileong
What?
What?
I repeat my earlier point: there is only one point in space which is theoretically in focus. If your equipment is calibrated properly and the film is flat, that point will be at the distance you have focused at. If you focused at 1 m, only objects at 1 m from your film plane are in focus, what's at 0.99m and what is at 1.01m are not in focus.
A lens is designed to gather light rays and focus it to a point that you decide, regardless of the size of the lens. This is why I say that focus has nothing to do with format.
DOF is a separate matter. How large the DOF is depends on various factors, such as aperture, distance, focal length, etc. You can look up the formulas, but in brief, the DOF of a medium format lens is shallower than that of a 35 mm lens basically due to the longer focal lengths involved.
As for why min aperture decreases with format-- I've never asked. I've never associated it with a COC issue. I always felt it was an engineering consideration, ie f64 is so small on a 35 mm lens it's hard to make the aperture blades stop down to that precision. Considering 35 mm lenses can be as short as 10 mm, it's not surprising.
Nevertheless, even if one can't build an f/64 35 mm lens, one can still do the theoretical calculations for DOF of a 35 mm lens stopped down to f/64. I'm sure it's larger than a 6x6 lens stopped down to f/64. If it's soft it would be because of diffraction, which is not a COC issue.
The only relation COC has to format is an indirect one, ie degree of enlargement. However, this may be counter-balanced by the fact that a MF lens has a shallower DOF compared to a 35 mm lens.
We can have a separate discussion on COC and DOF if you want. I know people argue a lot about these things. Eg I've seen heated discussion on whether DOF changes with crop factor on DSLR's. But my own experience with MF and 35 mm shows that for the same aperture, the DOF is much shallower on my Hassys, so I'm getting much more blurred backgrounds in my Hassy portraits compared to my 35 mm. I'm not sure if the lower enlargements from 6x6 fully compensates for the shallower DOF, I think that would make an interesting discussion.
What?
Finder said:Well, if the coc is not related to format, why does the minimum relative aperture decrease with the increase in format? Digital P&S have a minimum aperture of f/8 or f/11. 35mm, f/22, 4x5, f/64, 8x10, f/128. coc DOES change with format as what is considered "sharp" (a subjective quality) is a matter of the angular resolution of the human eye and, as you pointed out, "sharp" will be different for different folks.
This is why there is not one plane of focus, but a small range where an image will be "sharp," termed "depth of focus." This is also dependant of relative aperture. At f/64, a 35mm frame will be soft no matter how hard you try to focus.
"Sharpness" is a subjective quality. Format impacts it.
