Sparrow
Is hot film faster?
Obviously chemicals react faster when they are hot, is film the same? Anybody know?
Sparrow said:It must be me then, in the negatives from holiday this year I’m seeing a lot of variation in density roll to roll, more than my normal haphazard methods produce. We had very hot conditions this year, 50° in the town centre one day, and I seem to have switched from tending to under-expose to tending to over
No not sure of anything, just a tendency to be a bit over-exposed, a stop or two in the daytime mainly, across 18-20 rolls from three bodies, one mechanical and two electronic, r2a and r3a and an LFinder said:Are you sure the temperature was not affecting the shutter? Or if it had an automatic diaphram, the aperture?
Sparrow said:No not sure of anything, just a tendency to be a bit over-exposed, a stop or two in the daytime mainly, across 18-20 rolls from three bodies, one mechanical and two electronic, r2a and r3a and an L
I think almost everything will print OK so it’s not a big problem, just unsure what I did differently
keithwms said:I would expect the speed of nonchromogenic b&w film to be rather weakly dependent on temperature, because the photochemical reaction is on a rather different energy scale than the small variations in ambient temperature. if there were any variation at all I would expect the film to be very slightly faster at higher temps.
On the other hand, with colour neg film or slide, I would expect a somewhat stronger temperature dependence, simply because in those cases multilayers and couplers are involved. I don't know if higher temps would make the film faster or slower; there's no reason I can think of to expect a simple behavior- it might even be faster in one layer and slower in another, I wouldn't know how to think about that offhand. I would guess (guess) that the couplers become less efficient for temperatures outside the ~22-27C optimal range and then one would foremost see reduced saturation, and perhaps a change in dependence on colour temperature. Some couplers may have different temp dependence than others, and then you'd get colour shifts. With chromogenics that may be a bigger issue as well.
Of course, the temperature dependence during processing is quite extreme for all films.
