CosmicCharlie
When I sent my early m6 to leica for repair the Lietz red dot was Removed and replaced with Leica red dot. My pal says it changes the
collector value? is that really true?
erikhaugsby
killer of threads
To calibrate the M6's rangefinder removal of the dot is necessitated; I guess they just found it easiest to put a new dot on as opposed to preserving the original Leitz one.
I'm not sure on the value of this slight anachronism, though.
markinlondon
Elmar user
Was your early M6 collector grade to start with? Mint? Boxed? If you've been using it to take pictures, probably not. It probably doesn't make much difference.
Cosmic Charlie, How Do You Do?
A lot of big nuts prefer the "Leitz" dot on the Wetzlar M6 cameras, including myself. I would say you got gypped.
Go home, your mama's callin you.
CosmicCharlie
Thanks guys, I have all the original stuff, but it is a user.
CosmicCharlie
Nog, I will just sail around in my paper canoe with my beater m6
CosmicCharlie said:Nog, I will just sail around in my paper canoe with my beater m6
Say you'll come back when you can
Whenever your airplane happens to land
Maybe I'll be back here too
It all depends on what's with you
ErikFive said:There is something familiar about your voice.
I wouldn't belong to any forum that would have me as a member.
sepiareverb
genius and moron
I've never managed to remove a red dot without destroying it.
back alley
IMAGES
bye nog...
erikhaugsby
killer of threads
So I'm really confused...
JNewell
Leica M Recidivist
sepiareverb said:I've never managed to remove a red dot without destroying it.
Don Goldberg did that OK with my early M6, but in answer to the OPer's OP, I don't think I'd worry at all about collector value. Even never-opened-still-sealaed-in-the-box-we-had-to-Xray-the-box-to-prove-there's-a-camera-in-it M6s don't collect that huge a premium.
