jaffa_777
Hey check this out,
http://www.wikihow.com/Make-a-Good-Exposure
I certainly agree for most parts on the print and slide film instructions, but it's the B&W instructions that have got me bewidered. I am still learning film but is this for real?
Quote
If you are using black and white film, things get a bit tricky. Firstly, do not expose it as you would print film. You will get a very contrasty, hard to print negative. So, set your exposure compensation to underexpose the film by two stops. Again, you could also change the ISO setting, in this case you would multiply the suggested ISO by four, so if you have 400 speed film you would set the ISO to 1600. Next, meter for the darkest portion of your image and follow that reading. A center-weighted meter tends to work best for this.
Would this work?
Quote
Would this work?
