Koanut
Do you figure exposure with a meter (which one?) or do you rely on the old "sunny 16" rule.
Sekonic L-188 Auto Leader. Very simple, easy-to-use and small. Not very sensitive due to CdS cell; it only goes down to EV 3. Reflected light only, no flash metering. It's an amateur meter, no question about it, but I have shot even slides with it and the results were in general quite good. I use it with my Kiev 4 (even though the meter of my Kiev 4 is accurate, it only goes down to about EV 8) and my MF folders.mfunnell said:My metering requirements are pretty basic: all I want is something to "sanity check" my Sunny16 guestimates. I've found the VC II meter is good enough for that and comes in a nice convenient little package that is equally at home in my pocket or on an accessory shoe. If I had more complex requirements, or were shooting slide film etc. then I'd probably want something a little more fancy.
...Mike
einolu said:options for a digital light meter under $100? used sekonic 308... anything else?
