Here is a foolproof method for drying 120 or 135 B&W roll film without leaving watermarks, scratches or streaks. It’s a bit labor intensive but will be worth the effort.
The procedure is to wipe down both sides of your roll film simultaneously while it hangs from a film clip using two damp water-absorbing cloths each folded into the shape of a sponge.  The cloths will remove any water drops, which could contain mineral deposits.  The cloths will even pull the water out of the sprocket holes in 35mm film.  This procedure works well if you use a hardener in your film fixer and do not use a wetting agent,
There was a time when you could buy “photo grade” sponges for this purpose but I haven’t seen any for 20 years or more. Photo Wipes work well, but they become expensive if you are processing 30 to 40 rolls a week.
I have found by trial and error that the best material to use to create your own film-wiping pads is the smooth surfaced synthetic chamois or Microfiber automobile wiping/drying cloths found in automotive stores.  They are thicker, softer and more water absorbing than natural chamois and they contain no oily residue since they are man-made.  Most auto part stores sell these cloths. In the US, Pep Boys Auto Supply stores always have them.
A pair of these cloths/pads will last for years if properly cared for.
Email me for painfully detailed how-to-do-it information, as my explanation is too long for a forum post.
Walter Holt
