Burlap Jacket
The size difference between my Bessa R and Canon A2E is nuts..
Kim Coxon said:The MX's are OK as long as you use the M series lenses.
Kim
nikon_sam said:Kim,
I bought two MX's without the standard 50mm's and opted for the Vivitar Series 1 35-85mm & 70-210mm lenses...those were and still are heavy compared to the actual camera...adding the MX Winder helps with handling...
It's also cool to see that the MX is smaller than the Oly...😀
warren1960 said:I'm amused to see the Fujicas mentioned; I had the ST 705 and own the ST 801. I never thought of them as especially svelte, but the 801 is a good fit to my hands. The Fujica lenses are just brilliant.
Also for my hands, the OM's fit better than the Pentax MX, which seems just a little "blocky" in the palm.
The size of one's hands really determines what feels comfortable.
nikon_sam said:Kim,
Kim Coxon said:The MX's are OK as long as you use the M series lenses. They certainly feel unbalanced when using the original K series lenses. For those the slightly larger KX is better balanced.
The Fuji's especially the M42 ones are definately bigger but do have bright finders. The X series are smaller and better balanced.
Kim
IGMeanwell said:...
though I can say without a doubt the 58 1.2 is easily the most amazing lens I have used, it has that 3d quality to it that is hard to quantify and I will be using it quite frequently in the coming days (fall foliage)
oftheherd said:I never figured out why the bayonet mount Fujicas didn't do better. Marketing maybe? Or possibly they just waited too long to get into a bayonet mount which by then the magazines had convined everyone was the only mount a "real" camera could have. I am not sure their build was quite what the M42 mount cameras was either. That is just an impression as I never owned any of the bayonet mounts. Did you?
