C41 Dyi ??
JonR
2:29 AM
Maybe this question has already been asked but given how friendly everyone is here at RFF I will ask anyway....
I used to do a lot of darkroom work in the old days with PlusX and TriX, D76 etc and I know how that works.... Today however I only use C41 type of films both for black-and-white and for colour with Fuiji Reala as my favourite. I send it to the lab for processing and scanning.
Now to my question - is it at all possible to do the C41 processing at home on your own with quality and if so what chemicals/setup is needed ?? Sometimes you want to get the film processed directly and being able to do it yourself would be great....
Thanks!
Jon
I run a color darkroom (RA-4 prints) and I can recommend doing it yourself. I found the Jobo CPP-2 an excellent machine for keeping temperatures in control.
Except for a process that uses a stabilizer, I don't find color any more toxic than black and white.
Any of the Jobo processors that control temperature will be fine. The CPP-2 does it automatically so you don't need to worry about drift as the ambient temps change.
The Jobo CPE-2 goes for about $200 on eBay, or $300 with a lift. Now that's more like it. What does the lift do?
The lift makes changing chemistry easier and quicker. I highly recommend it.
Freestyle sells c41 and E6 kits.
As others have mentioned color processes require higher temperatures and good temperature control. A Jobo will make the process easier but you can do without.
Interesting - I will see if I can find any of those equipment here in Sweden - the Artistra for some 200-300 USD looks attractive - I didn´t even know this was possible !?
Thanks for info!
Jon
Are we talking about prints, negs, or both? Prints seem like they could be quite easy with RA-4 room temperature chemistry.
I should say- I've never dabbled in color. So just wondering out loud.
