Laforet
Nowhere Man
According to Dan Chang and his excellent service guide, the flare problem is when strong light light hit the verticle diffuser on the frameline illmination window (no, nothing to do with the RF patch)post-M3 models which causes excessive light to hit the RF patch and causes it to white out. So any post-M3 Leica is able to flare😛
The problem is made worse when Leica removed one condenser lens from the RF assembly. The condenser lens itself serves to brighten the 90mm frame and does not contribute to the flare; however some other parts had to be adjusted to compensate for its absence, and this is known to have caused subsequent cameras especially vulnerable to this problem.
One ingenious solution is to cover the illuminator window with a few layers of frosty tape, or with black tape if you can live without the framelines. SHADE from leicagoodies serves on a silimar principle using a slightly different material, I have not seen or used one so I cannot comment on that.
