vdonovan
Vince Donovan
I'm new to scanning and am using a rental scanner, the 8000, for 120 film. They have the glass carrier, which is nice.
My question is, is there anyway I can pre-scan all three images on a negative strip at once, and then select one image to scan. As I'm working now, I have to pick image 1,2 or 3 prior to pre-scan. It then pre-scans the image I pick, but for image 1 or 2 the prescan invariably truncates the negative, so I have to adjust the offset and pre-scan again. It usually takes several pre-scans to get it positioned right.
I hope my question makes sense. Last question: should I use anything special to clean the anti-newton glass?
thanks for your help.
Vince Donovan
Vince Donovan
