If you can live with a little inaccuracy, you could probably use the more easily accessible 21mm CV finder, which effectively is slightly narrower than the 15mm finder plus frameline, and approximate the FOV. With an ultrawideangle and an external finder the inaccuracy shouldn't be too bad.
