Wiyum
Lincoln said:-You have responded that the xpan takes images that are the same as 2 35mm's stitched together. This suggests that MF lenses are designed in the same manner as 35mm lenses(which we know they are not) Some have even suggested that they have a large 'sweet spot'...
Basically I am asking if the xpan print will look like a strip out of the center of a 6x7(with all the tonality of MF)...
Is tonality partly a function of MF lenses?
I know, the term 'tonality' is very subjective, but I hope my response will better describe what I mean. The x-pan looks like an excellent camera to me. If it can give me the tonality I want on a 35mm format , I will be happy. 🙂
Lincoln,
You bring up a good point, and you reveal that I did in fact misstate the facts earlier. An X-Pan print will not look exactly like two 35mm negatives stitched. Here's why.
You're right in stating that 35mm lenses and medium format lenses are not designed in the same way, but also quite wrong. All lenses are designed with a certain format in mind, and all lenses "draw" a projection that is a circle. Because one doesn't typically find circular formats, the rectangle of the format is inscribed within the image circle of the lens' projection. In a perfect world, there would be a uniformity of image quality within that rectangle, but this is rarely, if ever, the case. Lens design is a science of compromises, and the edge of that image circle always involves a falloff of both exposure and resolution. Unfortunately, the corners of a format often fall into this falloff area, and as a result there is a quality loss in the corners. This loss is typically slight in real-world use, but you can't enter an internet photography forum without finding people arguing about the soft corners of lens X or the irrefutable corner performance of lens Y. Regardless, there is usually a point where the image circle is falling off contained within the corners of the format rectangle.
For this reason, two stitched 35mm negatives would have corner falloff at the seam that wouldn't exist in the X-Pan print.
Medium format lenses quite certainly have larger sweet-spots, but that is only because there is a larger negative to cover. Viewed as a proportion of the negative that falls within the sweet spot, my guess, untested, is that you're looking at a similar percentage, and one that varies not only manufacturer to manufacturer, but also specific lens to specific lens.
The lenses for a 35mm camera should draw a circle with a minimum diameter of 43.27mm. The lenses for the X-Pan should draw a circle with a minimum diameter of 69.28mm. The lenses for a 6x7 camera should draw a circle with a minimum diameter of 86.04mm. These are again minimums, but they are the diagonal measure of the format rectangles. Lenses will always project a circle with a larger diameter, but the falloff will still creep in a bit.
For this reason, the cropped 6x7 negative would perhaps be slightly sharper than an X-Pan negative, assuming a center crop, because the corners of the resulting print aren't really going too close to the edge of that 86mm circle.
Notice, though, that I said sharpness. That's because sweet-spots pertain to resolution, sharpness, and exposure falloffs. MTF charts describe exactly this phenomenon, usually measured in line-pairs per mm, from the center of the image circle to the corner of the frame (the most extreme part of the circle being used).
Perhaps this is pertinent to your quest for tonality, and perhaps not. When I discuss tonality, I'm typically using it to describe differences in film stocks, and not formats or lens manufacturers. Regardless, I hope this is helpful in explaining what "medium-formatness" you could reasonably expect from the X-Pan.
Will
