gjlynx
Thanks for bringing up the sproket holes; I noticed this and thought it did not seem to be correct. The strange thing though is that if I push the take up spool all the way in,foto_fool said:One - my cynical side says that every eBay seller will tell you the camera has had a recent CLA 🙄.
TWO - it might just be that you have not mastered loading the film - the offset image drifting to the sprocket holes suggests this. IME to load the film properly you must remove the lens and hold the shutter open (you can use the T setting if it works - mine does not so I use the B setting and hold the shutter button open) while you manipulate the film so it is lined up correctly in the rails.
If this is not your loading protocol, check out the CameraQuest site:
http://www.cameraquest.com/ltmcam.htm
Look for "film loading" under "peculiarities".
the the sprocket holes are too far away from the sprokets to engage. When I try your technique the film does seem to stay engaged. Let's see what happens. I wonder why they don't mention it in the instruction book ?
