cosmonaut said:
			Since the IIIa is the first camera I have ever owned with out a meter I was curious how you meter your shots?
Most cameras have
some kind of meter these days. Those photographers whose cameras don't, or who choose not to use them, use handheld meters. These can be averaging meters, center-weighted averaging meters, spot meters, matrix meters incident meters or any of several other kinds. Most common in cameras are center-weighted averaging meters (that measure the average value of the reflected light, giving more "weight" to the reading from the center of the composition). The most common handheld meters combine incident metering and averaging meters. One thing they all have in common is that they will all give you an exposure recommendation based on a shade of gray called "18% gray." That is to say that they assume that anything you point the camera at is supposed to be this shade of gray (about the value of slightly tanned caucasian human skin). If it isn't, they will recommend an exposure that will
make it so.
For example, for the sake of simplicity, let's take a hypothetical situation in which you are shooting two different nudes, identical blonde twins, each of which has a different colored backdrop behind her. It's simple because the models are about the same color all over. One nude is standing in front of a white backdrop. The other is standing in front of a black backdrop.
So let's start with the nude with the white backdrop. You take the photo, develop the film and make prints. You will find that you have a photo with a gray background and the model is far too dark. Your film has been underexposed and you can't figure out why. You did what the camera said to do and it still came out too dark. What happened?
Well, when you turn on your camera's light meter what the meter sees is the whole composition, not just the model. It's just a machine that measures light. It can't recognize objects or what it is looking at. It doesn't differentiate between model and background, but what it does do --immediately -- is decide that the composition
as a whole does NOT average out to 18% gray. Even though Caucasian human skin is roughly the right shade, it also takes the background into account. It will recommend an exposure setting that will make the background and subject darker, in order that the composition
as a whole will average out to that 18% gray it wants. This results in underexposure.
Now let's photograph the model with the black background. Again, you aim the camera, adjust the exposure as the meter tells you to do, and take the photo. You develop the film and make prints. You are perplexed when you find that the background is still gray, but this time the model looks snow-white. Your film was badly overexposed. Again you are left scratching your head, and now you're wondering if the camera is broken.
The camera and the meter are both working fine. What happened is that the meter looked at your composition and found that, once again, it didn't average out to 18% gray. This time it was too dark (because of the black background), so it recommended an exposure that would make it average out to the "right" shade of gray. It overexposed your film, to make the composition lighter.
As you have probably figured out by now, the camera will only give you an exposure recommendation that is absolutely correct when the composition really is 18% gray. Unfortunately, in real life, this doesn't happen very often. What you have to do is recognize that this is happening and take it into account. You have to make adjustments for it. This is the method I use for landscapes, and I bracket. As you gain experience you will find that you can do this by eye, but fortunately for the beginners, there are three relatively easy ways to get around this: spot metering, incident metering, and gray cards.
In spot metering the meter only looks at one small area of the composition. There are a few ways to use this, but in the easiest, all you have to do is find an area in the composition that is close to 18% gray and meter the light on that. In our hypothetical nude photography scenario, the model's skin is pretty close to 18% gray, so this won't be a problem (just find a medium shaded part). What do you do if there is nothing in the composition that is the right shade of gray though? What if your model is an albino? What if she's black? Well, that leads us to the next easy method, grey cards.
If you are using a gray card, you
put something that's the right shade of gray into the composition, albeit temporarily. A gray card is simply a piece of pasteboard that is colored 18% gray. They're one of the few things in photography that are cheap. A gray card gives you something that you can hold in front of the camera that actually is the right shade of gray. You set your camera on manual, hold up the gray card, set your exposure, then set the card aside, focus, and shoot, relatively confident that you will get a good exposure. In a pinch, if you are light skinned, you can use the palm of your hand as a gray card. It works. Even so, it helps to bracket.
Well, there are two more ways of getting the right exposure, one easy and one a bit more difficult: the easy one is to use a handheld incident meter. Incident meters are very different from any other kind of meter. All other forms of meter work by measuring the light that bounces off of the model. Instead of measuring the light reflected from the model toward the camera, these measure the light that is falling on the model
directly. Instead of standing by the camera and metering the model, you stand by the model and point the meter at the light. This way there is no possibility of the meter getting confused by different colored backgrounds -- because it isn't even "looking" at your composition. These work very well for studio photography, but are not very good for outdoor use. Because of clouds and trees and shadows and stuff, the light where you are standing is often very different from the light on your subject and it just isn't practical to run over to a mountain, meter the light, and then run back to your camera. Heck, by the time you did that the light would have changed anyway. It works very well for indoor photography though, and I use incident metering on nudes a lot.
There is one more way of doing this, and it is called The Zone System; its a good bit more complicated than the simpler forms of metering though. In The Zone System, you use a spot meter to take several readings (the brightest highlight and darkest shadow where you want to show detail) and you work out an exposure that will give you what you want over the entire value scale, pushing or pulling your exposures in order to reduce or increase contrast if necessary. This is the system I use most times, if I have time for it, but it isn't the quickest method in the world. If you want to see how it works I suggest you look for it on google. I really don't want to try to explain it here, because I have already written about as much as I ever want to in a single forum reply just to get to this point.
Oh, and to do all this, I have my in-camera meters, a Gossen Luna Pro Digital F, a Pentax Spotmeter and an old Wesson-style GE selenium cell meter.
