btgc said:
Nick, so 14 fits into same hard case as G/GS/GSN ? That cases are nice to carry camera around, and if 14 comes on market without case it's nice to know that I already have case.
Yes - it fits in the exact same never-ready case as the GSN. However, the Lynx has a button on the front of the camera to activate the meter, so the Lynx case would have (I don't have a case for the Lynx) to have a "cut out" for the switch. You can use the GSN bottom 1/2 of the case anyway, you press the case where the switch is and it will activate the meter underneath. It works. Or you can cut out a section of the GSN case for the Lynx switch.
I just go "caseless" when using the Lynx 14.
Again, regarding the size, the camera body is
exactly the same size as the GSN. But that big azz lens 7 elements, 5 groups F
1.4 fast lens adds weight and makes it "front heavy".
The Lynx 14 is the
only fixed lens RF camera that:
1. Has all manual controls. Not a shutter priority
first camera with manual control "added on" as a feature/ after-thought.
2. Has
an F1.4 lens - did I mention that?
3. Has a quite leaf shutter
with flash synch at all speeds for fill flash - which I do use.
4. Has a parallax corrected viewfinder.
All manual controls - naturally, a 7 element, 5 group Tomioka Optical (very underrated) 45mm/F1.4 lens, a parallax corrected viewfinder. This is truly a
photographer's camera with
ZERO compromises. You can use any film speed (meters to 800), it is one of the best low-light performers...
Mine was restored to full functionality, I covet my fully operational sample, shoot it often, one of my favorite cameras, and wouldn't part with it. The stealthy little black RF it is not, however. It was never intended to be, doesn't pretend to be. And if you hate big cameras - stay away. But it does not
compromise lens speed (or quality), or sacrifice capability for the sake of convenience (like any "priority" camera of any sort). Again, it's a
photographer's camera.
