underbyte
I just received a Yashica 35CC from an auction and the cosmetic shape is good but there is a problem that I can’t figure out. I knew that the camera had a problem when I bid on it but I thought is was the ”pad of death” that I have fixed before in a GT using the "surgery" method. When I took the top off of the CC, surprise, it is not the same as a GS/GSN etc.
I installed a fresh battery just to rule out the battery. Here are the symptoms:
The battery check lights up but the shutter only fires at the highest speed like on a GSN with a bad pad.
The meter arrows light up but they are very finicky, you have to get the shutter button in just the right spot. I checked the battery compartment and it is very clean and I checked the bottom of the camera too. This is where I wonder if the problem lies. There are some brown wires soldered together in a suspicious poorly done manner.
1) I read on another post that the CC model has the same Pad. I know where it is on the GS/GSN series but I can’t see it on the CC. Can anyone point me in the right direction or does the surgery method not apply here?
2) Any other ideas based on the description of the problem?
3) What would make the arrow lights functional but intermittent?
It would be helpful to hear from someone that has done the POD replacement on a CC.
Any help is greatly appreciated!
Scott
Scott
