It's what you are after- a period-correct camera, or the image that has a bit more contrast and less prone to flare. The single coated lenses are fine performers, the Nikkor Multi-coated Non-AI lenses are like looking at rubies and emeralds. I use a factory-AI converted Nikkor-SC 50mm F1.4 on my F3. The lens is 10 years older than the camera, but it is just a great setup. And I keep a Nikkor-S 5cm F2 on an early F with eyelevel finder and 5.8cm F1.4 on a Nikon F Photomic. "not great performers", "Different look", Can only be explained by being potty trained too early.
With that said, I have enough cameras that are "period correct", and I do use them. But not as often as the ones that are multi-coated. For black and white, I'll grab the single-coated lenses. The lower-contrast looks better.
