Nikkormat Lens
feenej
6:54 AM
What Nikon lens would be period-correct for a Nikkormat FT or FS? Where is a good place in the USA for a CLA on a Nikkormat? Thanks.
Any Non-AI lens would be period appropriate. They are the ones with the solid rabbit ears. The little metal forks are the rabbit ears and they are used to connect the lens to the meter mechanically. The FS does not have a meter, so they aren't important there, but any of the cameras with meters prior to about 1973 need the ears. This includes all of the Nikkormats exsept the FT3 and the EL2 (I think, I'm going from memory here) The lenses with ears with holes in them are AI lens that will also work with later automatic indexing cameras
I had my Nikkormat CLA'd by: Quality Photo Service Camera Repair, 654 Ogden Ave, Downers Grove, IL, Phone: 630-493-0780 about a year ago and they did a fine job.
I believe that the HC lens is too late for your camera. the 'C' means multi coated and I'm sure that didn't arrive until the early 70s.
A more correct lens would be the 50mm f2 'H' lens or the 50mm f1.4 'S' lens.
Any other lens that doesn't have the 'C' after the lens letter would be reasonably accurate, as long as it wasn't too early.
Regards
Ernst
As stated, the Nikkor-H 50mm F2 or Nikkor-S 50mm F1.4 are "period correct". But a multi-coated lens will be more flare-resistant, and will not cost any more in this day and age.
ernstk said:
...A more correct lens would be the 50mm f2 'H' lens or the 50mm f1.4 'S' lens....Regards
Ernst
I'm with Ernst- I've got a student with a beautifully brassed black FT and the 50/2.0 H lens, they were purchased together according to his uncles memory. They appear to be made for each other. My book (Moose Peterson Nikon Guide) lists them as concurrent.
Another student has the chrome FT but with a 35-70/3.5 lens that just doesn't look right at all on that body.
Another lens you might want to look at is the 105mm f2.5 or 135mm f3.5 with silver filter rings. I have heard good things about Essex Camera Repair for a CLA.
It's what you are after- a period-correct camera, or the image that has a bit more contrast and less prone to flare. The single coated lenses are fine performers, the Nikkor Multi-coated Non-AI lenses are like looking at rubies and emeralds. I use a factory-AI converted Nikkor-SC 50mm F1.4 on my F3. The lens is 10 years older than the camera, but it is just a great setup. And I keep a Nikkor-S 5cm F2 on an early F with eyelevel finder and 5.8cm F1.4 on a Nikon F Photomic. "not great performers", "Different look", Can only be explained by being potty trained too early.
With that said, I have enough cameras that are "period correct", and I do use them. But not as often as the ones that are multi-coated. For black and white, I'll grab the single-coated lenses. The lower-contrast looks better.
Another place that specializes in Nikon overhauls is Pete Smith Photo in Lake Worth, FL. Maybe someone else can supply the link or e-mail address. I've had him do work for me and he is great.
Essex Camera Repair in NJ can do just about any camera, so they'd be another good option: www.essexcamera.com
Okay. This is a camera forum- pictures help.
This is the 50mm F1.4 lens that was current when the Nikon F Photomic T was out, which is the same vintage as the Nikkormat FT:
attachment.php
"Nippon Kogaku" instead of "Nikon", change-over made ~1967, and a "V" shaped meter coupling ridge. Later changed to a curved shape. The V shape is "not optimal" for a Photomic head, but is fine for a Nikkormat.
attachment.php
A 5.8cm F1.4 preceded the 50/1.4 by a couple of years. Not made in "BIG" numbers, but plenty of them around when the FS was introduced. Very different optical formula than the 50mm F1.4 lens. Closer to a Leica Summarit.
attachment.php
And I've been tempted to replace the coupling ridge myself- does not stick with the Photomic Meter as well as the later ones.
attachment.php
