summicron 40 on m3 and normal lens dillemas
Michael I.
8:42 AM
Israel \ Ireland
Hi,All!
I currently have a m3 with summaron(goggled). I am contemplating selling the summaron(which gives wonderfull results,specially after cla by Sherry Krauter but I hate the goggles with a vengance) and getting a 40 summicron.
Will it give as plesant a look to my Black and Whites?How is it in color?
Will it give worse distortions then a 50?
What say you?How usable is it with the 50 framelines of the M3? Will it make any other ones pop? Is it a good substitute or should I get a nokton 40/1.4 and thats it?:bang:
I can't offer comparisons to the 50, but I can say that I find my 40 works well on my M3 - I use the entire VF including outside the 50 framelines for composing.
I had two Summarons (googled) to go with my M3 but the googles made the camera a little to heavy and bulky for my taste. Now I use my Summilux 35mm pre with an external VF on the M3 and everything is fine.
Same here. I use the entire viewfinder for composing with the 40mm M-Rokkor on the M3. It works fine.
I haven't noticed any distortion with the Rokkor (which has the same optical formula as the Summicron-C), but actually I haven't looked for it. Neither the 50mm Summicron-M nor the 50mm/2.8 Elmar-M has any noticeable distortion.
Richard
Again, I use the 40mm Summicron C with the full VF and it worls well. I've compared the full frame to the 40mm frame on the CL and they're almost identical.
I think the Summicron C renders wonderful black and whites; it's the perfect compromise between an old flarey lens and a modern contrasty lens for me. It's also wonderfully compact on the M3, specially if you use the rubber shade that was designed for it.
"I hate the goggles with a vengance) and getting a 40 summicron.
Will it give as plesant a look to my Black and Whites?How is it in color?" I don't think so!! These lenses are worlds apart.
