ZorkiKat
ЗоркийК&
- Local time
- 1:21 AM
- Joined
- Jan 26, 2006
- Messages
- 2,070
foto_fool said:Seems like those Dotwraiths are going to have some rich pickings out here in our neck of the woods 😀.
Rest a ya can keep yer scissors, Leitz trimming tools (and copies) and even yer cards. Taking the lens off and putting the shutter on B works fine, I'm getting 38-39 shots per roll, and I'm not leaving little bits of film laying around (which are classified as toxic waste in our State) :angel:.
Taking the lens off, setting the shutter at B and 'fingering' the film to coax it through the channel can be, potentially damaging. The camera parts concerned may indeed be made of metal, but they can be displaced.
At the least, this method adds 7 extra steps to the loading process:
1-Taking the lens off.
2-Setting the shutter to B.
3-Opening the shutter.
(The loading sequence as required by bottom loaders follows, then when the spools are in place, the next extra steps continue🙂)
4-Putting the finger through the lens mount to coax the film in. The finger presses the pressure plate with more force than just film alone. This is one possible source of damage.
5-Releasing the shutter to close it.
6-Replacing the lens.
7-Setting the shutter speed to some other speed to wind film and fire blanks until the first frame is positioned.
You would need a place to safely put the lens on, too. The baseplate at least can be slipped into the pocket. And exposing and touching the camera like that increases the chance of getting dirt into the works as well.
Do those little strips less than 10mm wide and about 5cm long really become potential pollutants? Isn't the whole exposed leader trimmed during or after processing and thrown away just the same?
As the 'pro-cut' advocates above have mentioned, cutting the film leader to the proper shape isn't hard to do. It's only one extra step, compared to the additional 7 with the run-around methods. And it's fool-proof, or at least proven since Leitz figured that it's the best shape for their cameras. Proper loading can be done in 30 secs or less once mastered. My time for today was 13 secs. 🙂
Jay
