Just looked at this thread by accident (Bessa R doesn't have this problem) and realized your eyepiece is the same as my F-801 slr. Do what I did for it:
Take the camera with you to a hardware store... the old fashioned kind. Ask to see their "O ring" selection. Find the size that fits and buy 3 or 4 (they're cheap - like 80 cents each) and a bottle of contact cement (about $4). Go home, rough one side of one O ring on sandpaper (or a fingernail emery board).
Spread a little contact cement on a piece of card stock, and press the rough side of the O ring into it. Remove the O ring, turn it over and let it dry completely (allow 15/20 minutes.) With a toothpick or the stick from a cotton swab, carefully run a line of contact cement around the outside rim of the eypiece and let it dry completely.
When both are dry, position carefully and press together. Other than drying time, the whole procedure should take less time than it took "old two-fingers" to type this. This procedure also works well on eyeglass-killing Rooski rangefinders.
