New Zorki 6 plus FED-2 Dressed to Kill
dazedgonebye
3:39 PM
Arizona
Just received this Zorki 6. Really, I don't know why they don't get more attention. It's not quite as pretty as the FED-2, but it shares a long baseline and adds a better viewfinder, better diopter adjustment, crank film wind and an honest to God hinged film back.
I just ran a quick test roll through to check for light leaks.
Ok, I admit this might be overkill. My FED-2 is dressed for wildflower hunting with a CV21mm, the finder and a VCII meter.
Nice looking stylish camera but for the cheap plastic (?) name plate attached with 2 screws. What! no more engraved names? But what else to not like?
Very good looking pair, Steve!
John, the name plate as it is on the Z6 leads me to some interesting thoughts about what one could replace it with.
Rob
I'd like to hear some of those ideas Rob.
Yes, the soft release was a splurge for an inexpensive camera, but I just had to have it in commie red.
Call it a vain indulgence.
BTW, it did not come with that jupiter 8, I just had that laying around.
Steve,
I don't think the SR is an indulgence on these cameras, or not mine anyway, the shutters typically aren't so smooth to start with and the Mini SRs I have on my FED and Zorki make a very big improvement.
As to the other, since you asked:
"Zorki 6" but written using the 30s era Cryllic script is the first thing that occured to me.
Or something a little egotistical like your name (or alias😀).
Or "Smile"?
Or maybe just some small graphic.
Or, for onery-ness "27mp full frame sensor"...😉
Or your phone number.
Or "This is not a camera"
All kind of silly to be sure(except the first, I think) but not too involved or expensive to play with probably.
Rob
i saw few z6 and all of them rip film after 20 shots. i always have too loose film in ints canister if i want to avoid rippping. anyone have better idea for fixing that?
radiocemetery said:
The Zorki 6 looks great. Hope it works out OK. By the way, I was thinking of getting a soft release for my Fed 2, but I figured the soft release would exceed the cost of the camera. 😱
Steve
Fedka had a cheap one - works okay, but I lost one and was forced to order three more to be safe. Don't see them on his site now, you might drop him a line if you can't find it either if you are interested.
The shutter release is stiff.
I got a roll through in testing and will have it developed tonight to check for light leaks.
Yea, that fed-2 is over dressed, but functional.
hi dazedgonebye,
Zorki 6 is a nice camera.i own one too with an Industar-50 in aluminium finish.it looks better!
the jupiter-8 in black finish is an earlier model.it was prodused after 1976,but Zorki 6 only until 1966!
there is also jupiter-8 in aluminium finish,so if you find one just replace it!(Z6 came with Industar 26m,industar 50,jupiter-8 aluminium finish.)
maybe it is not important to you but i mentioned it just for the record!
I'm working through my first roll with a green-skinned Z-6 (love the look), Cyrillic, 1960 vintage. Some nice features of the camera: Easy engagement of the film leader via a tongued takeup spool, similar to the spools for the Ms (only attached to the camera so you can't lose it!); long baseline, as mentioned above; vertical RF adjustment is very simple and convenient; terrific diopter adjustment -- I'm very nearsighted but I can use the camera without glasses.
Having the two flash connectors on the front makes me think of those sand creatures from the first Star Wars movie.
Mine came with a badly "cleaned" Industar-50, which I promptly replaced with a nice one from another RFFer. Mounting a J-8 is decidedly luxe -- not sure if it's historically accurate, though. I'm looking forward to seeing the I-50 results.
Oh, and I'm pretty sure the screwed-on nameplate is metal, not plastic. Back in the late 50s-early 60s I think everything was still metal of some sort.
I did get my film back and the camera looks light tight with no obvious shutter problems. This is going to replace my fed-2 as my normal FSU shooter.
As for asthetics of a black lens...not a big deal for me...though thanks for the historical perspective.
