How fast can you load a Leica M?
M
M like Leica M6
Guest
A few days ago I discovered Tom Abrahamsson's Youtube video on how to load a Leica M.
http://www.youtube.com/watch?v=CEyt94xMNUY
Of course, this was made as an educational film.
But HOW FAST can you load an M6 or MP or similar?
Show off your prestidigitation and tell me how to do it quickly on location with the shot of your lifetime waiting to be taken in the next few seconds.
(I can load my M6 while I walk, holding the base plate jammed between ringfinger, little finger and middle finger 😀 )
Andy: where does the pint glass go while you are doing this (I usuall balance mine on my head). 🙂 Seriously, this is an excellent description. I used my MP and one of my M3s last fall in Japan, and I must say that I had an easier time loading the M3 than the MP. Not sure why, except I did notice the the film leader must be pretty darn flat to work well in the MP, whereas it does not matter when using a separate spool as on the M3 or my M2. Thoughts?
Oh, by the way, why rush to load a camera anyway? I like what Garry Winogrand said when asked if he worried about missing any shots while loading his M4. He said there were no shots to be taken while he was loading the camera. I like that thinking.
Be well, shoot lots!
After 20+ years I still get it wrong once in a while and the only thing that constantly saves me is my training to tighten the rewind and WATCH the rewind as the film advances!-Dick
Not as fast as Tom, but I almost never have problems loading an M. Actually, I loaded my new to me M2 with easy so far, even easier than my M3 with rapid load kit installed.
The flip answer is not quickly enough.
It takes me 30 seconds to two minutes to load.
I've yet to find a method to avoid the best light or action occurring while loading.
yours
FPJ
Depends on how cold my fingers are, but I can generally get the camera loaded in less than a minute- including opening the film can. I'm much faster sitting down unless I'm standing at the counter in the darkroom. M7 is slower to load due to the fiddling required to get the shot film out- those DX readers can get quite a grip on a roll of efke 25.
Before I got a Leica, I was warned that changing film was different and difficult. The first time I did it, I couldn't believe how straight-forward and simple it really was. Under a minute easily, with rewinding and opening the new film box/can being the long part.
one thing - I am clumsy, so I always (well, usually!) put the base plate in my pocket while I'm stuffing the film in.
I think I unload and reload my MP in 30s or so; my M2s or M3s take an extra 10-20s. But, with the MP, I have had to fiddle with getting the film into the sprockets, whereas with the M2/3s, once I learned the secret about getting the leader snugly against the inside drum of the spool, I have never had to fiddle. I think the old M2/3-barnack spool thing is fiddle-proof once you get it down pat 😉
I don't see what the big deal is with the base plate. Why is everyone wondering where to put it or how to hold it? I believe we all have pockets?
You obviously haven't been reading the thread about naked photography ... the mind boggles on where the baseplate might go! 😱
I bought an extra one of those M2/3 Barnack spool thingees, which I preload with Eastman XX, then it resides in a box of Kodak Snap-Caps. Loading takes about 15 seconds, if I am fiddly, using a preloaded Leitz spool. Just drop her in, jiggle, advance, throw on the Rapidwinder, she's ready to go. That fast.
I must admit ... every time I pop a new film in my Ikon and snap the back shut I think fondly of my M7 (not)! 😛
Someone tell me they can reload a Barnack in under a minute and I'll be really impressed! 😉
It takes me roughly 1 to 2 minutes to load my M4-P (baseplate dropped into some pocket) but slightly longer to load my M3 with "quick-load kit" ... Usually, I try to avoid changing film in the street or other open and crowded places, it draws to much attention ...
Remember that the Youtube was done slow to show some of the tricks. I havent timed myself lately, but it should not take more than 20-25 seconds. Usually I do carry an extra body loaded and just switch them and wait for a suitable time to re-load. The base-plate, or in my case the Rapidwinder usually goes into my right jacket or vest pocket. Occasionally I have held it with my teeth, but considering the cost of dental care, it is not recommended.
The biggest problem with the M4 and later "tulip" take up is that unless you get the film in properly, it will not slide over the sprocket "teeth". My bending the end of the film in a small 90 degree angle gives the tulip something to "bite" into and less chance of slipping.
The M2/M3 gives you a quick "visual" that the film is in deep enough with the small perforations on the spring catch. Always push it at least 2 holes and preferably 3 holes in to the catch.
That is an awesome video, I am impressed. It takes me ten minutes, but I usually light some candles first.
10-15 flat
10-15 flat
Yes you can load an M6 fast.I learned(from a National Geographic shooter I met in Mexico) to indeed hold that base plate between your lips or teeth(I personally have no dental problems to date) It saves 20 seconds off putting it in your pocket.Actually I carry an M6 and an M4P always so at least one has film for that once in a lifetime decisive moment.
