New TMAX 400 in DDX
Photon42
burn the box
3:28 PM
Neutral Zone
Hi, chefs de cuisine
I'm sitting here with a new TMAX and still quite some of Ilford's DDX developer. Couldn't find any information for the above combination, so I checked the massive dev chart for a pattern with Kodak's own developers. I found approx:
HC110 -10%
D76 -10%
XTOL +10%
dev time for new New TMAX in comparision to the old one. Old and new are pretty close, it seems.
Would you consider it safe to start then with the old TMAX values, that is, 8 min (ASA 400)?
Thank you for your thoughts on this and regards
Ivo
I don't what else you can do. Unless someone pops up with a time. If it were I, I'd go with +10% just because I hate thin negatives. Do you have an old time? If you do use that + or - 10%. 10% is about 45 seconds so it will probably have an effect.
Could you please share the results with the data, gentlemen?
I would like to ask the author of the post what's the reason to use DDX?
I haven't got the new Tmax yet as it's not here unfortunately.
data was posted, so what? To me, it looks sharper than the Fuji 400 I was using before. I was using DDX because I still have some😎. You're probably better of with the TMAX developer.
Regards
Ivo
