I wonder if the idiot that smashed the Thorium Based Takumar knows that it emits Alpha Rays? The radioactive elements are inside the lens, and the Alpha rays can't penetrate. Now- if you smash it into Dust, and breathe it in- irradiate yourself- I suspect that suing Pentax won't get you very far.
If you ever get bored with it I'd like to have a play 😛 Should be able to fix it if only the element got placed wrongly.
That lens looks like a Kiron. The same lens, a 28mm f2.5 was also sold as a Vivitar.
If so, it's a superb lens, very sharp and good even wide open.
You must have a mis-assembled, as suggested, or physically damaged lens. Maybe it was dropped.
.... I'll play with it first. Seems a shame to spoil a perfectly bad lens.
Not to mention the fact that he destroyed a perfectly good lens. That yellowing goes away after a few days in the sun doesn't it?
Matthew
They are mixed into the glass; they are not rattling around loose in there. Smashed, they just mixed into glass chips instead of a big chunk of glass.
Opinions are somewhat divided on that. Apparently, sometimes it does and sometimes it doesn't. I've seen one Takumar that had actually gone past yellow and was into brown. I really doubt that setting it in the sun would have done much for that one. I agree that this was dumb though, unless he had already tried the sunlight fix. I put that up there mostly for its humor value.
Beavis and Butthead camera repair.....🙄
Interesting. Specialist soft-focus lenses where you vary the softness with the aperture cost serious money and are relatively rare. Seems like you've got a cheap one.
Matthew
Gallagher comes to mind...
At f2.5....
