v500 is here and works quite good
martin-f5
6:07 AM
the only thing I dislike is the neg. holder,
when the film is not flat,
nothing handles it
Martin, glad you finally received your V500. Well done image there! Yes, they are decent scanners for the money and I do have to agree about the film holders.
hey Wray great to hear from you,
did you scan negs with holder?
is that possible?
this is a print scan
and I think it comes closer to my way
A-h-h, two more well done images! Prints do scan well don't they? Yes, I'm still using the stock film holders. Here's a scan I just did this morning of an old "Woodie" from an auto show this weekend.
It's Fuji Superia 400 shot a 200 ISO. Yes, I've seen those glass inserts and seriously considering purchasing.
I use a Nikon Coolscan V ED for my 35mm scans, but recently picked up a V500 for medium format. I never used the stock, flimsy, floppy, 2-frame-only film holders. I had already ordered the variable height holders from betterscanning.com, and I love them. I also use VueScan exclusively on both 35mm & 120. Great results. I find I always scan at 3200dpi rather than the available 6400 though. I haven't needed the 180mb(!) files from 6400dpi. The 50mb files from 3200dpi suffice! ;)
Oh, and I looked at the V750 before purchasing. As far as I can tell, the V750 would be mandatory if I wanted 4x5 or 8x10 scans (shudder.... haven't bitten that yet.... but...) with its second lens. But the V500 is better than okay for 6x6 (with the aftermarket holders) and I much much much prefer the LED backlight instead of fluorescent, for ease of use, immediate startup, evenness of lighting, and ecological friendliness.
and now, color dia scanns:
the 35mm holders for the v700 are quite fine. The 120 holders are not so fine, if the film is curled, but i still manage with them. The scanners' DOF is quite large. Just have to make sure the film does not cur so much that it would touch the scanner glass!
6x4,5 Mamyia TriX in Rodinal 1+50 (grainy !)
and Denis is chocking :)
the mf filmholder is much better than the 35mm one,
some years ago I had a problem....
I know, I have to stop it,
but 6x7 neg. had to be tested
full and coped
Martin, thank you so much for the post. I am still looking for a MF (6x7) scanner and appreciate your V500 samples. Excellent photography.
Martin,
You do not need to stop on my part. I am enjoying your photos. Thanks posting these scans as I am looking for a medium format scanner at the moment.
