Paul C. Perkins MD
Perk11350
Then you're not buying it either - eh?     ;-)
	Brian: My Summar looks to be uncoated, with serial number 4075xx.
Tom: It is earlier than the lens you are looking for. What is so special about the summars with serial numbers mentioned by you?
	Gosh!
All this Summar lore in one place! Mine is I think an early one (1934 - but I'll have to check) and is in generally good, though probably not mint condition. I'm intrigued as to whether it's one of these more collectable 'black nose' versions or not. Not that it will affect my use of it.
I think on reflection (geddit) I'll make the effort to obtain a decent lens hood for it, though I'd hope not to have to pay the equivalent of $100. What should I look out for Leica Tom?
	Raid,
Ohh it`s just the year I want, the #491xxx+ lenses are uncommon and the gear matches up better for me with most of my "wartime" /postwar US Army equipment (it`s more a collectors thing I guess, with this lens being the last version of the formula as well as in construction)
Leitz had most of the Summar stock all gone by the start of hostilities in Europe and some of the last of these lenses sold were by Leitz New York in July/August 1939 - they were all stamped in "feet"
And as for the way it shoots, call it flare/glow who cares.........it`s a good performer for it`s time and now is a very beloved lens for bringing back that "vintage look" in photography (use a hood and the performance is just what it`s supposed to be......a perfect black and white film lens)
Tom
Finally!! I may get a chance to make you drool, Tom.
My Summar is in between Raid's serial and your (418***) marked in feet and it look like new (really!). There is a little llight haze inside + a couple of dark spots, but otherwise really clean. I have been meaning to send it to Sherry for a CLA, but have not had the time, nor will I before I go to Istanbul in a couple of weeks. Sorry, no pics from it at the moment, as it has been boxed up waiting to go off for service.
I think I'm going to unpack it and take it with me to see if it can capture the flavour of Byzantium in B&W. I will post results here 😉
Back to that hood question....with the Leitz Summar hood, it`s all luck and where you find it, on evilbay they can go for $65 to $100 that seems to be the going price, if you can buy one under those prices quoted, you have made a deal, I think Kodak made a hood (prewar) and Waltz (postwar) both are also, uncommon, I don`t think a FISON (Elmar 50mm) hood will work well on a Summar, I`m sure it would vignette and anyway - the FISON hoods are
NOT CHEAP either, they run from $60 to $200 depending on what era they are from, the 1920`s 30`s black versions are very collectable and the 1940`s one is also rare and not often seen - I`ve noticed even the beater hoods on evilbay seem to get fought after, I`ve never seen one sell for under $50
Some FISON hoods are marked for some "interesting" lenses. I've seen them with marks for Summar 50mm, Hektor 50mm, and Elmar 35mm. In every case, said mark is at the fully-collapsed position, at the end of the chrome section. The normal 50mm position is only for the Elmar, with it's very small front element.
The FISON is a more practical part of a travel kit. (Elmar 35/3.5, Summar 50/2.0, Elmar 90/4.0, FISON, VIOOH, and IIIa in my case.)
