dreilly
Chillin' in Geneva
- Local time
- 11:08 AM
- Joined
- Dec 25, 2004
- Messages
- 1,045
That lens might suck or it might be the best thing ever...I have no idea. But those photographs are really wonderful, thanks for sharing them!
Just a note, I am going to try out the summicron on my bessa for a few piles of film then see what happens, work with different exposure values then see what happens, with my bessa I think its a lot easier to mess with different things with more consistency, thats one thing that keeps coming back in my head, the bessa is more consistent then the m6.
So ... do you think it is more a lens-related or camera-related issue ? What would you expect being more consistent with the Bessa, the AE advantage ?
One of the things that I noticed when using a AE camera like the bessa and its excellent light meter is that the negatives are more consistent in thickness, saturation, etc, one of the tricky bits of the m6 is that you are stuck to whole shutter values and half aperture values, and sometimes there is a half or a third off and that can change a lot of the characteristics of a negative. I noticed this best before with my GSN, when shooting xp2 at 400 the contrast was much higher then when I shot it at 320, a large difference in the negatives indeed, but 320 gave more glowing skin tones and more overall tones but was lacking more in the deep blacks, not that you could not alter that with some darkroom work or a tweak of the levels in photoshop, but it will be interesting to see what happens as a camera to camera difference.
I think you would really like the 28mm Biogon, but I urge you to find a way to hold on to your Summicron. You really make nice images with it.
To bump this up again, I have a question to your processing, Colin.
Do you alter much of the photo's tonality/contrasts after scanning in Photoshop? If so, what do you do with it? :angel:
Yes and yes, I do alter in photoshop. The scans I get back are always dull looking but that is the way I want them, its difficult to get good results from a direct scan and easy to clip highlights with a contrasty scan. I like to use the levels in photoshop a lot, also layers and the bw function is neat as well. Why the black and white function (CS3) when the photo is already black and white? Simple, because the scan is not actually black and white, its a color interpretation of black and white, so there is actually something you can play with in the color channels with a black and white scan (this varies between scanners) and can be useful for getting a little extra detail out of a shadow or tweaking the image to your taste.
