Skeletor
Hello!
Right now I1m sitting in my room playing with a borrowed M6 and 35mm Summicron.
What annoys me is the fact that i can`t meter the light with apertures wider than 2.
Yes my room is pretty dark, but i`ve read somewhere that the meter has been improved during the assembly line of the M6.
Is this true?
The serial number of the camera I`m using is 1759685.
Thanks
Is this true?
Thanks
eia41
There is nothing wrong with your camera. In low light conditions you must either use a higher ASA film, a faster than your Summicron lens, or (God forbid if you are a purist!) a flash-gun.
Skeletor
Thanks for your reply.
I know that is nothing wrong with the camera. It´s just that I reached the limits of the metering system (changing the iso setting won`t help in this case of course).
What I want to know is if the sensibility of the metering cell was increased in later models of the M6.
Chriscrawfordphoto
Real Men Shoot Film.
You can't meter with apertures wider than f2 with any camera using the 35mm Summicron because f2 is the Widest aperture that lens has.
John Bragg
Yes I think that is true.. I think it has been mentioned recently in another thread.
Skeletor
Sorry. Of course I mean smaller than f2.
:bang:
Skeletor
Thanks John.
Do you remember at which serial number it was increased?
ampguy
The M6TTL increased sensitivity by a fraction or whole EV from the M6 classic according to the Advanced Leica M book specs. I don't know of any metering changes in M6 classics.
Andrew Sowerby
Fresh batteries?
Livesteamer
You have an early M6. My first M6 is 1768457 and it will meter as low as f1.0 at 1/8 of a second with asa 400 film. My 166xxxx body seems to have the same metering ability. I don't think fresh batteries would make a difference. Just give the camera a try and see if you like it. Good Luck, Joe.
Skeletor
Hhmm...this might be another advantage for the TTL. I like the bigger speed dial too. I don`t like the larger size of the cam.
Puhhh, I think price will make my decision which one to buy.
Andrew Sowerby
Haha, the larger size of the TTL? It's what, 5mm taller or something?
kipkeston
I'm almost positive you need a new battery
Skeletor
Yes, it`s a difference that I notice. It`s not a big issue but it is one.
Skeletor
I´m gonna check it but i don`t think so only ten films or so have been gone through the cam with this batteries so far. And the metering is corect too.
mknawabi
photographeur
Don't take this the wrong way, but...you're crazy dude.
rxmd
May contain traces of nut
2.5mm to be precise. The M3 is 77mm, the M6TTL is 79.5mm, the M5 is 84mm, and an M3 with a Leica MR meter is about 95mm.Haha, the larger size of the TTL? It's what, 5mm taller or something?
Philipp
oscroft
Funnily enough, I too think that the extra 2.5mm height of the M6 TTL spoils the lines of the camera a bit. It wouldn't be enough to affect a purchasing decision, but the M6 Classic definitely looks better to me.
FifthLeaf
amateur
The M6 meter doesn't give different readings as the battery dies down. You may have trouble reading the meter because the LEDs grow faint, but those faint LEDs are still accurate.
I know this from experience and reading the manual.
tom_uk
Rather amusingly, page 28 of the Leica M Advanced Photo School book (Osterloh, 2005, English) reads:-
"The camera housing is about 2.5mm (1 inch) higher....".
Wrong by an order of magnititude! : 25mm = 1 inch, not 2.5mm!
