Xtol + Rodinal 1st roll
ItsReallyDarren
That's really me
3:42 PM
Bay Area, Ca
After reading so much about the Xtol and Rodinal combo I thought I would give it a try.
The results are impressive, the rodinal helped tame the highlights. Its not very noticable in the picture but the negatives show extremly fine tonal ranges. Grain has also gone up a tiny bit as opposed to souping in Xtol alone, its hard to tell with a film like Acros.
So far Ive only done 1 roll but Im definetly going to try out different times and dilutions.
I uploaded the original full size versions on flickr, have a look.
In the set I have two versions, PS=photoshop, tweaked with the levels and curves a little. The other comes unedited from the scanner.
(fyi; the M1 Ive noticed has a tendency to mellow out the contrast of a negative)
http://flickr.com/photos/dkatin/sets/72157605957936058/
That looks very promising and good to me. The tonality is well balanced and lots of fine details visible. That must look great as a wet-print !!
I have tried this combination only once (XTOL 1:1 + Rodinal 1:100, 15 min at 20 degrees) to "save" a roll of ACROS that I had accidentally exposed as an 400 ISO film.
What dilution time did you use ?
Wow, that combo is stunning! It makes me want to forget about the HC-110 I'm using and try this. Are XTOL and Rodinal powder or liquid developers?
XTOL is a powder developer and you have to make 5 liter of solution at once ... (and it should be used within 4 month or so and stored without to much air - oxygen - in the bottles)
Rodinal is a liquid concentrate that lasts forever. It is getting brown with time but that doesn't have any effect.
What dilutions?
What dilutions?
Yes - all examples have great details in highlights - so what are the dilutions Itsreallydarren?
Maddoc - when you say XTOL 1:1 + Rodinal 1:100, is that a 50:50 mix between the diluted xtol and diluted rodinal? Or is it say, 500 ml of water, 5 ml of rodinal and 500 ml of undiluted Xtol?
Are the shadows blocking up a bit or is that just my monitor?
DaveW
...That looks very promising and good to me. The tonality is well balanced and lots of fine details visible. That must look great as a wet-print !!
What dilution time did you use ?...
I cant wait to get these negatives in the darkroom!
I used Xtol at 1:1 (300ml) and Rodinal 1:100 (6ml) and 300ml of water. Developed for 8:30 with 2 inversions / 5 seconds every minute at 20C.
I think Ill try Xtol at 1:2 for the next roll.
This sounds pretty similar to what I have used. In my case it was:
XTOL 1:1: 250ml of XTOL stock solution + 250ml of water and then I added 5ml of Rodinal concentrate to the 500ml XTOL. Gives a total of 505 ml solution.
