Developed my first C-41 tonight...
gdi
4:37 PM
West-Central Connecticut
It is quite a bit easier to mix up than E-6 - but I'm not sure if I am willing to switch totally to negative film. I actually find slides easier to scan, but the DR of the print film is very attractive.
Anyone else here doing C-41 at home? What compells you to do so? For me it is really the convenience of doing it at home, due to the lack of labs doing 120/C-41.
Here are a couple from my first rolls, Portra 160VC, Mamiya 7II...
wow those look really nice! colors on the boats a bit saturated, but that's why it's called VC. looks very crisp and clean though. what resources if any online did you use to find out how?
Well, congratulations are due! I wish I could do it... although, on the other hand, if I could, I don't think I'd do it.
Does it require precise temperatures?
Do you need a bleach bath?
How many steps are involved?
Did you use a developing kit from Freestyle, or some such store?
Did you scan your negatives?
Let us know. Inquisitive minds...
And, again, congratulations on a well done job! 🙂
Ive seen kits for home C-41 processing but always shyed away because the high temperature scare me.
How was the development process? Is good ventilation a must for C-41 and E-6?
The chemicals smells from photo labs drives me nuts after Ive been in there too long.
Thanks for the comments - here are some specifics...
I cheat with all development and use a small PhotoTherm Sidekick processor that was retire from a small lab. I The unit is programmed for a 4 step C-41 process, 6 step E-6 process and B&W. Mix chems, load film, push a couple of buttons and go do something else for a 1/2 hour, then hang them to dry...
I used Kodak chemicals bought separately in concentrate for 1 gallon - 3Part Dev, Bleach, Fixer and Stabilizer. The bleach is premixed so it is really easy. E-6 is a 7 Step and, accordingly more tedious to mix. The proper ingredients to buy can be found in this thread - http://photo.net/film-and-processing-forum/00Lu65
I do this in my "barn" (really a 3 car garage) with 2 of the big doors open and a small fan usually running to keep the air moving. It really doesn't smell much. I am scanning with a Nikon 9000.
BTW, I noticed a bit of cyan cast in some scans - this is where Negs are difficult. With slides I can check color on the light table, now I have to see if it was the dev or the scanning at fault!
Wonderful, maybe you'll eventually start a small niche business to offset the cost of running that processor 🙂
Back to the pictures, yes, I see a cyan cast. You may be able to compare the scans from other lab processors to determine whether it's a dev or scanning problem.
Congrats! I, myself, just got into developing c41 last weekend. It certainly wasn't as difficult as some people say it to be. But then again, I'm wondering if the people who say it's hard to do are just armchair experts who haven't actually tried it out.
Unlike yourself, I do not have a processor and do it by hand, and using a 3 bath kit from Freestyle. The biggest (pleasant) surprise for me was that it wasn't as temperature intensive as I originally perceived it to be. The only temperature/time critical part was the first bath: 102F (39C) for 3.5 minutes. The entire process for me, from the time I loaded the spool to the time I hung it up to dry, took about 15 minutes. Much faster than any BW developing I've ever done.
I highly urge anyone whose done black and white but have always wanted to do C41 but were afraid to to try it out.
Thanks again for the comments and its good to see I am not the only one wacky enough to do C41! (Yes, Mabelsound, I would give it up if my supermarket processed 120!)
Anyway I tweaked my scanning settings a bit and I think i am good to go. Here is another one of the shots - I think the color balance looks better now, no?
I do it in a JOBO processor or a Nikkor stainless tank. Use a waterbath and have a gallon of hot water to add as the temp falls i9f you use the Nikkor tank ( not all at one time). Put the water bath in a tray on a piece of styrofoam to act as insulation or just use another upside down tray. A countertop really sucks the heat out.
Only the developer step is super critical. The rest have an easy tolerence.
Prewarm the tank and reel and film so you do not cool the developer as it is added.
Ok for you guys doing C-41...
Is the main reason because you do 120/220 etc. and lab processing takes a long time? Or...
I've been wanting to do C41 myself for a couple of reasons. First, I just wanted to try it out and see what it was like. Secondly, I've been getting extremely annoyed with my regular lab's poor level of service. I could take it to another lab, but my only alternatives are Walmart, Costco, and other 1 hour labs. However, what really pushed me to do it was because I recently got into 4x5 and developing costs per sheet can get quite expensive. Now, if I can find some kits or formulas for E-6, then I'm all set! 😀
