S
schaubild
Guest
The facts are dividing the focal length in mm by the diagonal of the film frame. For the Mamiya that would be 43/89,3 = 0,48 The Biogon on the Hasselblad 38/79 = 0,48. The Biogon on the special Alpa 44x66 mm holder 38/79 = 0,48. The Fuji 690 GSW 65/99 = 0.65 at most as I''m not sure the frame length is 82 mm. The customised Fuji 690 with the SA 47 mm 47/99 = 0,475. It is the original Brooks Veriwide that really beats that 0.48 ratio of the Mamiya with 47/115 = 0,41 if that frame length really is 100 mm. All more or less in the spirit of this thread. Relatively compact, MF and wide angle. The bigger Mamiya Press with the 50 mm lens on 6x9 (56 x 82 mm) = 0,50, the Koni Omega 56 mm on 6x7 even more.
Of course the Fotoman, Linhof, etc panorama cameras can go beyond that ratio. Not to mention the Cirkut concepts like the Voyageur that works with 120 film.
In readily available, not breaking the bank, MF, more or less compact and very wide, quality image, the Mamiya 7 II with a 43 mm lens is the obvious answer.
Ernst Dinkla
Sorry, read the wrong message. From a view-angle point of view you're right. I received this as a quality related message, therefore the stiff answer
The Biogon for Alpa is no longer produced, but there are the Super Angulon XL 38mm (image circle of 96/139 mm (f5.6/f22)), the Alpar 35mm (image circle of 105/120 (f11/f22)) and the Helvetar 48 mm (image circle of 98/123mm (f5.6/f22)), all three easily cover 6x9. And the Switar 36mm with it's image circle of 90mm can be used on 6x7; direct comparisons against a Biogon have shown that this lens is at least as good, even full open. Just a side remark.
