75mm M4-P frameline + Nikkor 8.5cm
#FT2_8*fffg.
1:47 PM
Does anyone use this setup with the 75mm frame lines?
I have both, but don't know whether I should find the Canon brightline viewfinder. I don't like the small clunky dial in viewfinder that came with the lens.
Does your finder not have lines for 90mm? I'd be concerned using the 75 frames, as it will show a view a fair deal wider than your 85mm, possible causing key elements near the border to be lost.
I use the 85 Nikkor with the M4P, and like they say, the 90mm frame lines work fine.
