Body for J-12
mtk
2:22 AM
I have cheap options for jupiter 12 at the local marketplace. But i cannot choose a body for it. accesory viewfinders are not widely available here, in fact i haven't seen any of them yet.
So i need a body, with viewfinder for 35, 50 and preferably 85/90 for J9.
i like bessa R very much, but only some jupiters are compatible as users say here.
as i figured out on internet, canon 7 is also incompatible. so show me the body😛
also many people are enjoying j12 here with fsu cameras, and if there is no body for my tastes what is the viewfinder you use with them?
thanks in advance..
Zorki 4 has 50mm finder right? i have got zorki 6 that i like, but need more framelines..
I purchased a J-12 attached to Zorki 4 - but too be honest I never shot a roll with that combination (not sure why). I have, however, used the J-12 with my Bessa R and I found that worked well; mostly because I liked using the very clear and bright finder and because I didn't run into any problems with focusing incompatibilities - but then I never went more open than f4 and so depth of field was fine and covered any minor incompatibilities that I might have experienced. I also preferred the Bessa over the Zorki, Fed 1, or my IIIf because it does have internal finders for 35 mm & 90 mm and I used a CV 35/1.7 with the Bessa body.
I've also used a Russian turret finder but I found that clumsy to use because it seemed to me to be awkward on top of the camera and really the combined size defeated the point of a rangefinder for me - I tended to think - this was especially true of the turret rangefinder on top of Leica II-III's and the Fed Zorki derivatives (although ymmv). I've also used a Helios (35,85m,135mm) finder which is much smaller than the turret finder and may be worth considering. Not that it's as good a finder as the Russian turret finder (which has correction for parallax, separate views for each focal length and a much clearer view). The Helios has 3 focal lengths all in the 1 view window (if that makes sense) - but in terms of letting you frame a picture it's a snap to use. If a little yellowy amber to look through.
However I find all of these options to be less pleasant than the Bessa's viewfinder: If only for its combined RF/Viewfinder and the fact that I find using an external viewfinder somewhat clunky. Of course if you don't mind focusing and using a seperate viewfinder then this may not be an issue for you. I love using my CV 15mm with its viewfinder - but then I'm not trying to use the rangefinder in that instance.
Of course J-12's are a lot cheaper than Bessa bodies. But really, why fight the urge? Get the J-12, a Bessa, an M3, a Zorki, a Fed, another J-12 on the end of a Kiev, a ...
BTW, what 35mm / 90 mm lenses are you considering?
yes, maybe 65$ is resonably priced, i haven't thought bput that really.. but shipping to Georgia costs a lot also.. and..
well i prefer buying a camera body than the finder..
but if there is no camera for my needs, well, then i'll consider turret finder..
i plan to use jupiters mainly, 8, 9 and 12. because they are widely available and very cheap. 3$ for 50mm(excluding j3 that i have never seen in person) and 20$ for the rest.
and i want a cam to use them.
tyrone.s
don't you screw tha lens all the way, or is there other focussing incompatibility?
i would prefer bessa over canon 7 in fact.
that was fun reading, thanks.. i may try it some time.. but for now i need a more conservative way to solve my problem..
p.s. i've already got zorki 6 that i like a lot..
These two were bought on Ebay for about UK £10 each,-the one off the camera gives a 1:1 view with my 50mm lenses!, both give a lot better view than the turrets and quickly placed, as the lens is changed. 🙂.....obviously no
paralax correction, but this is'nt a problem for me with this camera-if I want CLOSE, I usually grab an SLR, - or guess!!
Cheers Dave.
thanks, well the viewfinders seem to be easyli obtainable.. and if it was for the camera body, to use with 35, 50, 85/90 what would you choose?
I have cheap options for jupiter 12 at the local marketplace. But i cannot choose a body for it. ...
thanks in advance..
I have a J12 and two Canon 7 cameras and a Canon 7s. The lens fits all three.
I understand there are two formulations of the J12. Some fit the 7, the others do not.
that's weird really.. about the differences in lens construction.. but let's leave it alone.. so if i get a jupiter 12 of a certain type, it will be perfectly compatible with both canon 7 and the bessa r?
and does anyone know the serial number range for this type of lens?
what else? i didn't know leningrad had framelines, but it must be overcrowded to show all of the 4 together. drug or droug is rare, i haven't met one.
what else?
This has been discussed recently.... Search back a month or so ago. My J12, a black late model one (7602153) fits (just) on my Bessa R. Of course it cuts out the meter and it doesn't focus to infinity. But hey, I can still use it....
