question for the optics / lens gurus
Papercut
1:51 AM
Westchester county, NY (and Chongqing whenever I c
I'm considering getting a reasonably priced portrait lens (75 - 90mm) for my Zeiss Ikon ZM. Two of the candidates on my short list are the 90mm Elmar (LTM) and the 90mm Elmar-C and I'm just wondering if there is any (real, noticeable) optical differences in these two lenses?
With the M-mount adapter for the thread mount lens the prices are within $50-75 of each other, so price isn't really an issue. I'm just interested in optical differences.
While the optical formula is probably identical (one never knows about what undocumented tweaks were done) you can expect differences in coating and mechanics. The Elmar-C has a slanted RF cam. And I am guessing just like for the 40/2, sometimes during the Elmar-C production multi-coating was introduced.
I were you, I would try to get a 90/4 Rokkor, different (better) RF cam, and definitely multi-coated.
Best,
Roland.
In terms of the look of these lenses, I don't have anything from a more modern Elmar or Rokkor, but the pictures below were taken w/ a clean, uncoated Elmar 90/4 black barrel from the 1930s:
Kevin -- I think it probably is, but I used an improvised hood consisting of a couple of step-up rings screwed together, so I didn't have a problem w/ flare. It's the way the lens renders colors that I find most attractive, but I had to return the lens to its owner and wound up getting the Canon 100/3.5 as my long lens.
