best close up option on M system?
sanmich
8:40 PM
I know RF's are not meant to shoot bugs.
I just want, from time to time to go under 0.7m.
What would be my best option IYO:
1- DR summicron with eyes
Pros: ease of use (no need to unmount the lens to put the eyes on - AFAIK), maybe slightly better lens?
2- coll cron with SOMKY
Pros: weight, size, price
What argument did I miss?
What would you do and why?
THANKS!🙂
Viso III + OTZFO (?) + 65 Elmar.
16526H (BOOWU-M?) + 50/2 Summicron -- a much underrated combination.
90/4 Makro-Elmar
75/2 Summicron
-- in that order. And I've tried all of them.
I think, after having used the 75mm, I'm going to agree with Roland. I haven't used Roger's selections (save for the 75mm) so I can't comment on those but definitely you can get "close" with the 75mm.
Dave
Use a longer lens. Like a 90mm at 0.9m or a 75mm at 0.7m.
Roland.
Roland, thanks for answering!
I just checked. Indeed the 90mm give a bit closer at 0.9 than the 50 at 0.7.
the 75, well, that seems a good solution. Not quite in the weight or price range of an accessory. Also, my M2 and M3 will have some king of a prob to handle the FL....
16526H (BOOWY?) + 50/2 Summicron
90/4 Makro-Elmar
75/2 Summicron
Dear Roger,
The visoflex seems quite an operation. Not the kind of things i'll have in my bag "just in case"
the 16526H (BOOWY?)
what is a 16526H (BOOWY?) ???😕
I'll consider the option of the makro-Elmar
Thanks again!
Dear Roger,
the 16526H (BOOWY?)
Thanks again!
Dear Michael,
The Viso is less bulk and grief than you might expect -- but the III is MUCH easier to use.
Google BOOWU or BOOWU-M (typographical error already corrected) and you will find what appears to be a real Heath Robinson/Rube Goldberg device -- aka 'spider legs' -- that works astonishingly well. The great advantage of BOOWU for bugs is that you don't need a viewfinder: just use the 'frame' provided by the legs. It's really remarkably easy for bugs.
I decided not to get a Makro-Elmar because the Viso goes down to 1:1 and besides, I already have the Viso/65 combo and a 75/2 and a 16 5256 H.
although the summicron DR is very sharp and it's not that much of a hassle with the goggles, i want to sell it if you are interested 🙂
I use a +1.5 diopter auxiliary close-up lens, which I have carefully calibrated to determine the plane of focus. I also have a +5 close-up lens. The +1.5 focusses at 18 inches from the lens, and the +5 at 8.6 inches.
I have the 90mm macro elmar and I really like it. Without its goggles, the 90mm macro elmar captures the same image field as the 50mm DR Summicron WITH its goggles. I like having the extra distance of the 90mm, and the lens is really sharp with very nice out-of-focus rendition. It is expensive, but worth it to me. I have the googles for it (they allow up to 1:3 reproduction on film) but I haven't used them much yet. If I want to do something that close I think of using a tripod, and if I think of using a tripod then I think of using a different camera system. Still, when I'm traveling I always take the 90mm macro elmar.
I think the answer today is just the same as it was in the 1970s, when my dad looked at a Visoflex, weighed up the pros and cons… and bought a Pentax SP1000.
In recent years I have been tempted to buy a Viso to put on my M6. I've tried the Leitz extension tube/copy legs set-up, but it really is a dog's dinner next to an SLR…
