What is this optical phenomenon called (pix)?
Rodluvan
10:29 PM
Stockholm - Sweden
I've seen in many of my photos (especially those with shallow DOF) that the circles of confusion in them-self stretches as to form a circular shape with the centre in the middle of the frame as can be seen here:
Not very apparent here, but a little:
And here, especially at the bottom of the frame (could be fooled by vignetting though?):
I've only seen this in film from what I can recall. Maybe because it's not that outspoken on a cropped sensor.
Any suggestions?
Thank you/
Daniel
That's coma, where the outer edges of the lens focus light at different points to light closer to the centre. It's correctly called abaxial spherical aberration.
Marty
"Swirly bokeh" as in the first frame ? Can be seen often when using older lenses, especially three element lenses like the Tessar design and having a inhomogeneous background (trees, leaves). Have a look in this thread here at RFF.
btw just a minute later I realized in first picture at medium distance on bush is so nice effect. Maybe even nicer than light donuts in further...upper part. They make me talking in terms closer/further instead of upper/lower part of image.
Marty
And here was I thinking the stretching was due to the aperture forming an ever thinner ellipse as seen further and further away from the lens axis..
Rodluvan, is this the phenomena you are describing? I've always wondered what caused that. 🙂
This was taken with a Leica Summar at f2 or f2.2
I think that is correct, this would be coma - creating a "tail" on round highlights. The highlights are become more V shaped with distance from the center of the frame...
Tessars are modified triplets (as also Leitz Elmars are), in which one of the elements is composed by two lenses.
It's based on a triplet design, yes, but the modification (which consists of replacing one element with a two-element group) then makes it a four element lens in a 3-group configuration - "element" referring to each individual piece of glass, and "group" referring to each cemented set of pieces of glass - "lens" refers to the entire assembly. You don't have an "element" made of two "lenses", you have a group made of two elements, and thus a lens made of three groups (and four elements).
