drjoke
I have been underexposing by 1 stop on purpose to compensate for the fact that M8 appears to have less dynamic range on the highlight side. That way I don't clip highlights so often.
absolutely not. the m8 has plenty of highlight detail if you just use the recovery option in lightroom. if you go around underexposing you're going to introduce noise into the image.
Today I underexposed by 1/3 as I found that all my images were a bit over-exposed when using the 35mm Summicron.
If I use auto -- which I do, quite a lot -- mine certainly doesn't overexpose most subjects. Or maybe it's just the subjects I choose.
Then again, I've only taken about 9-10,000 shots so far...
...if you go around underexposing you're going to introduce noise into the image.
Perhaps that's true with the M8, but not the R-D1. I routinely shoot -.7 to -1 stop. Noise in the shadows isn't nearly as great a problem as highlights that don't exist. I only notice it at iso 1600, and the problem can always be solved by crushing the blacks. 😀
Dear John,
Nope. Sorry!
